Тема: RTU650 c тремя CMR
ваяю конфигу. вроде все по феншую, при компилировании не ругается, но, будучт залитой в устройство - не стартует. логи такие.
2018-09-12, 16:48:56.094 (ST TIV) CMU 0 [rack address 0, slot 2]: Starting up ...
2018-09-12, 16:48:56.094 (ST TIV) CMU 0 [rack address 0, slot 2]: Wrong rack or slot address.
2018-09-12, 16:48:56.358 (ST TIV) User Account Management on CMU 0 [rack address 0, slot 2] starting up ...
2018-09-12, 16:48:56.445 (ST TIV) User Account Management on CMU 0 [rack address 0, slot 2] running ...
2018-09-12, 16:48:57.094 (ST TIV) CMU 0 [rack address 0, slot 4]: Starting up ...
2018-09-12, 16:48:57.094 (ST TIV) CMU 0 [rack address 0, slot 4]: Wrong rack or slot address.
2018-09-12, 16:48:57.094 (ST TIV) CMU 0 [rack address 0, slot 6]: Starting up ...
2018-09-12, 16:48:57.094 (ST TIV) CMU 0 [rack address 0, slot 6]: Wrong rack or slot address.
2018-09-12, 16:48:56.762 (ST TIV) XRP Server on CMU 0 [rack address 0, slot 2] starting up ...
2018-09-12, 16:48:56.762 (ST TIV) XRP Server on CMU 0 [rack address 0, slot 2] running ...
2018-09-12, 16:48:57.358 (ST TIV) User Account Management on CMU 0 [rack address 0, slot 4] starting up ...
2018-09-12, 16:48:57.357 (ST TIV) User Account Management on CMU 0 [rack address 0, slot 6] starting up ...
2018-09-12, 16:48:57.446 (ST TIV) User Account Management on CMU 0 [rack address 0, slot 4] running ...
2018-09-12, 16:48:57.444 (ST TIV) User Account Management on CMU 0 [rack address 0, slot 6] running ...
2018-09-12, 16:48:57.758 (ST TIV) XRP Server on CMU 0 [rack address 0, slot 4] starting up ...
2018-09-12, 16:48:57.759 (ST TIV) XRP Server on CMU 0 [rack address 0, slot 4] running ...
2018-09-12, 16:48:57.755 (ST TIV) XRP Server on CMU 0 [rack address 0, slot 6] starting up ...
2018-09-12, 16:48:57.756 (ST TIV) XRP Server on CMU 0 [rack address 0, slot 6] running ...
2018-09-12, 16:49:01.550 (ST TIV) CMU 0 [rack address 0, slot 2]: Startup stopped.
2018-09-12, 16:49:02.100 (ST TIV) CMU 0 [rack address 0, slot 6]: Startup stopped.
2018-09-12, 16:49:02.149 (ST TIV) CMU 0 [rack address 0, slot 4]: Startup stopped.
но. если оставить только три CMR, то работает. я так понимаю, что весь затык происходит после добавления слота входов и шины SPB I/O BUS. что я делаю не так?
пару скринов когда работает и не работает, причем после добавления слота входов, компилятор настоятельно требует добавить  SPB I/O BUS
релиз ртутил 12
Добавлено: 2018-09-14 11:43:56
джемпер на корзине. S1. номер  RUCK. надо поставить первый номер.  странно всё это.... но видать так должно быть, работаем дальше, спасибо!
сори ежели побеспокоил, реально три дня потратил.
Добавлено: 2018-09-14 13:46:44
еще странно, что будучи физически назначенной с номером 1 корзина в логах идет под номером ноль http://rzia.ru/uploads/14211/thumbnail/qYEdTr3jaiDu7ZX2CzLb.png http://rzia.ru/uploads/14211/thumbnail/qYEdTr3jaiDu7ZX2CzLb.png
не работает.png 16.16 Кб, файл не был скачан.
работает.png 11.42 Кб, файл не был скачан.
2 (2018-09-15 11:09:49 отредактировано IgorSL)
Re: RTU650 c тремя CMR
Такое ощущение, что у Вас не настроены адреса CMR.
Номера должны быть:
1 на slot 2
2 на slot 4
3 на slot 6
А у Вас в логах все CMU 0
Нормальный вид лога:
2018-06-19, 10:10:40.101 (WT TIV)    CMU 1 [rack address 1, slot 2]: Starting up ...
2018-06-19, 10:10:40.129 (WT TIV)    CMU 2 [rack address 1, slot 4]: Starting up ...
2018-06-19, 10:10:40.507 (WT TIV)    Database on CMU 2 [rack address 1, slot 4] starting up ...
2018-06-19, 10:10:40.509 (WT TIV)    Database on CMU 2 [rack address 1, slot 4] running ...
2018-06-19, 10:10:40.509 (WT TIV)    User Account Management on CMU 2 [rack address 1, slot 4] starting up ...
2018-06-19, 10:10:40.619 (WT TIV)    Database on CMU 1 [rack address 1, slot 2] starting up ...
2018-06-19, 10:10:40.621 (WT TIV)    Database on CMU 1 [rack address 1, slot 2] running ...
2018-06-19, 10:10:40.621 (WT TIV)    User Account Management on CMU 1 [rack address 1, slot 2] starting up ...
2018-06-19, 10:10:40.643 (WT TIV)    User Account Management on CMU 2 [rack address 1, slot 4] running ...
2018-06-19, 10:10:40.738 (WT TIV)    User Account Management on CMU 1 [rack address 1, slot 2] running ...
2018-06-19, 10:10:40.952 (WT TIV)    XRP Server on CMU 2 [rack address 1, slot 4] starting up ...
2018-06-19, 10:10:40.960 (WT TIV)    XRP Server on CMU 2 [rack address 1, slot 4] running ...
2018-06-19, 10:10:41.046 (WT TIV)    XRP Server on CMU 1 [rack address 1, slot 2] starting up ...
2018-06-19, 10:10:41.054 (WT TIV)    XRP Server on CMU 1 [rack address 1, slot 2] running ...
2018-06-19, 10:10:45.170 (WT TIV)    CMU 1 operable
2018-06-19, 10:10:45.170 (WT TIV)    CMU 2 operable
2018-06-19, 10:10:47.187 (WT TIV)    RTU active
2018-06-19, 10:10:47.205 (WT TIV)    SNTP Client 1 on CMU 1 [rack address 1, slot 2] starting up ...
2018-06-19, 10:10:47.210 (WT TIV)    SNTP Client 1 on CMU 1 [rack address 1, slot 2] running ...
2018-06-19, 10:10:47.214 (WT TIV)    Host Interface line 'MicroSCADA' on CMU 1 [rack address 1, slot 2] starting up ...
2018-06-19, 10:10:47.224 (WT TIV)    SNTP Client 1 synchronized
2018-06-19, 10:10:47.514 (WT)    RTU synchronized
CMR02.png 6.53 Кб, 1 скачиваний с 2018-09-15
