http://www.dailymail.co.uk/news/article … ckout.html
Действительно, очень трудно отыскать маленькую жемчужину достоверности в чудовищной куче информационного навоза, наворованного друг у друга и наваливаемого в газеты и интернет всезнайками-журналистами. Привожу небольшую ссылку iz (на мой взгляд) наименее недостоверной статьи из интернетовского издания:
[...]officials from Arizona's largest electric utility said on Friday they are still baffled by the chain of events that caused massive blackouts across Arizona, California and parts of Mexico.
APS has said they believe a single employee at the North Gila substation tripped a 500-kV transmission line that runs from Arizona to Southern California.
They are investigating how that happened and the subsequent failure of safeguards that should have prevented major outages. [...]
Early Thursday, APS officials noticed an issue with a series capacitor at the North Gila substation outside the city of Yuma, Mr Froetscher said.
The capacitor — a piece of equipment about the size of a small car that helps the utility manage voltage — wasn’t functioning properly.
APS personnel were dispatched to take it offline, the LA Times.
Typically, the utility can shut down an individual capacitor and reroute power without any disruption of service, Mr Froetscher said.
But this time, something went wrong. After the North Gila capacitor was taken offline, the 500-kV line that runs through the substation went down.
At that point, 3.27pm, the grid should have compensated for the loss of the 500-kV line, which runs from Yuma to the Imperial Valley and San Diego.
'The intent is for the system to automatically open and close different breakers and relays and switches to reroute power from the line that was lost to other lines to continue to provide service,' he said. [...]
'Transmission lines do go out of service on an unplanned basis; it’s not an unusual event. Most times when a line goes out unexpectedly, the system performs exactly as it’s expected to and customers never know the difference.'[...]
[...]По заявлению представителей крупнейшей Аризонской энергетич. компании, они до сих пор крайне озадачены событиями, последовательность которых привела к массовым отключениям в Аризоне, Калифорнии и в Мексике. По мнению АПС отключение ВЛ 500кВ, связывающей Аризоны и Южную Калифорнию произошло по вине одного из работников на ПС Северная Гила. Причины несрабатывания противоаварийной автоматики - выясняются.
Днем ранее, в Четверг, были отмечены неполадки (какие - не уточняется, прим. мое) в работе Последовательного Конденсатора, установленном на данной ПС. С целью вывода Конденсатора из работы на ПС была направлена ОВБ.
По заявлению м-ра Фретчера, вывод Конденсатора из работы, с последующим перенаправлением потоков мощности, как правило, не приводит к отключениям потребителей. В этот раз - произошло по-другому: линия 500кВ, проходящая транзитом через ПС отключилась после вывода Последовательного Кондесатора из работы.
По регламенту, в этот момент автоматика должна была скомпенсировать потерю данной ВЛ-500, связывающей города Юма, Империал Вэлли и Сан-Диего. Назначение системы [ПА] состоит в авоматической и согласованной работе реле, выключателей и разъединит с целью перенаправить поток мощности на другие линии, заявил г-н Фретчер
Незапланированные отключения - обычное дело, и в подобных случаях система срабатывает как было запланировано и событие никак не сказывается на потребителях.
Далее текст статьи повторяется в том-же ключе.
Примечание: в подавляющем большинстве американ систем существует такая штука как RAS (Remedial Action Scheme), о которой и говорится в статье. На наших ПС 500кВ для нее выделены по 2 реле SEL-421 на линию, разработка уставок на которые была (по цене) равносильна запуску Шаттла на Альфа Центавра. :lol: :mad:
Над этими реле приделаны, и бьют по глазам, большие красные плакаты: "Выводить из работы - ТОЛьКО при разрешении Системого Диспетчера!!".
Могу предположить, что релейщик в ОВБ самостоятельно вывел РАС из работы, что и привело к падению первой костяшки домино. Но это только предположение. Поскольку 99% линий 230кВ и выше имеют МП защиту и синхронизированы через IRIG-b, и даже иногда через синхрофазоры - Всеамериканская Чрезвычайная Коммиссия (ВЧК), в просторечии именуемая NERC (North American Reliability Concil) - собирает записи событий с многих сотен реле, с регистраторов аварийных событий, и другой аппаратуры.
Остаётся добавить, что в момент аварии - по никем пока не отмененному Закону Подлости имени мистера Мерфи - стояла жара выше 100 градусов по Фаренгейту (около 40 гр. Цельсия в тени). В нашей компании, Диспетчер никогда не даст разрешения на вывод РАС в подобных условиях.
Господа, не следует подобно газетчикам и их благодарным читателям, второпях бросаться наземь и биться манжетами о паркет.. ;)
Думаю, через пару, тройку месяцев мы узнаем полную картину того что случилось..
