1 (2012-12-20 21:03:26 отредактировано sk19x)
Тема: Проблема с PCM600!
Добрый вечер всем! )))
There was an unexpected error in PCM600: PropertyTable does not exist: 0c75caa0-3f6b-4029-a74f-b04249ee1513, _PCMFrame_
OS Platform:             Windows 7 Ultimate
OS Service Pack:         Service Pack 1
OS Version:              6.1.7601.65536
Processor Count:         1
Product Name:            PCM600_2
Product Version:         2.4.1
Product Status:          PRODUCTION
Product Build Number:    93
Application Domain:      PCMFrame.exe
Assembly Codebase:       file:///C:/Program Files/ABB/PCM600_2/bin/PCMFrame.exe
Assembly Full Name:      PCMFrame, Version=2.4.93.0, Culture=neutral, PublicKeyToken=null
Assembly Version:        2.4.93.0
Assembly Build Date:     30.01.2012 10:29:32
Language Package:        ABB PCM600 ru-RU Add-On
ConnPack Name:           ABB Generic IEC61850 IED Connectivity Package
ConnPack Version:        2.4.3
ConnPack Status:
Build Number:
Path:                    C:\Program Files\ABB\Connectivity Packages\Generic IEC61850 IED\2.4.3\
ConnPack Name:           IED Connectivity Package RED615
ConnPack Version:        4.0
ConnPack Status:         PRODUCTION
Build Number:            50
Path:                    C:\Program Files\ABB\Connectivity Packages\RED615\4.0\
ConnPack Name:           IED Connectivity Package REF615
ConnPack Version:        4.0.1
Build Number:            2
Path:                    C:\Program Files\ABB\Connectivity Packages\REF615\4.0.1\
Exception Source:      ABB.PCM.ProjectDataServer
Exception Type:        ABB.PCM.Data.Exceptions.PropertyTableNotFoundException
Exception Message:     PropertyTable does not exist: 0c75caa0-3f6b-4029-a74f-b04249ee1513, _PCMFrame_
Exception Target Site: GetPropertyTable
---- Stack Trace ----
   ABB.PCM.Data.DataStructureObject.GetPropertyTable(tableName As String)
       PCMFrame.exe: NativeOffset 01060, ILOffset 0532
       PCMFrame.exe: NativeOffset 01411, ILOffset 0679
   ABB.PCM.Data.DataStructureObject.GetPropertyValue(propertySpecName As String, tableName As String)
       PCMFrame.exe: NativeOffset 00282, ILOffset 0163
   ABB.PCM.Data.SystemDataServer.GetRoot(toolName As String)
       PCMFrame.exe: NativeOffset 00379, ILOffset 0174
   ABB.PCM.Navigator.frmLogin..ctor(kernelObj As IPCMKernel)
       PCMFrame.exe: NativeOffset 00358, ILOffset 0121
   ABB.PCM.Frame.Starter.h()
       PCMFrame.exe: NativeOffset 00086, ILOffset 0026
   ABB.PCM.Frame.Starter..ctor(debugModeEnabled As Boolean)
       PCMFrame.exe: NativeOffset 00608, ILOffset 0272
   ABB.PCM.Frame.PCMStartForm.a(A_0 As String[])
       PCMFrame.exe: NativeOffset 00368, ILOffset 0202
---- End of Stack Trace ----
<ILExceptionData>
  <Point module='ABB.PCM.ProjectDataServer.dll' classFull='ABB.PCM.Data.DataStructureObject' methodName='GetPropertyTable' methodSignature='ABB.PCM.Data.PropertyTable GetPropertyTable(System.String)' methodToken='0x60001d2' ILOffset='532' />
  <Point module='ABB.PCM.ProjectDataServer.dll' classFull='ABB.PCM.Data.DataStructureObject' methodName='GetPropertyTable' methodSignature='ABB.PCM.Data.PropertyTable GetPropertyTable(System.String)' methodToken='0x60001d2' ILOffset='679' />
  <Point module='ABB.PCM.ProjectDataServer.dll' classFull='ABB.PCM.Data.DataStructureObject' methodName='GetPropertyValue' methodSignature='System.Object GetPropertyValue(System.String, System.String)' methodToken='0x60001dd' ILOffset='163' />
  <Point module='PCMKernel.dll' classFull='ABB.PCM.Data.SystemDataServer' methodName='GetRoot' methodSignature='ABB.PCM.Data.IDataStructureObject GetRoot(System.String)' methodToken='0x60001e4' ILOffset='174' />
  <Point module='PCMLogin.dll' classFull='ABB.PCM.Navigator.frmLogin' methodName='.ctor' methodSignature='Void .ctor(ABB.PCM.PCMInterfaces.IPCMKernel)' methodToken='0x6000006' ILOffset='121' />
  <Point module='PCMFrame.exe' classFull='ABB.PCM.Frame.PCMStartForm+Starter' methodName='h' methodSignature='Boolean h()' methodToken='0x6000010' ILOffset='26' />
  <Point module='PCMFrame.exe' classFull='ABB.PCM.Frame.PCMStartForm+Starter' methodName='.ctor' methodSignature='Void .ctor(Boolean)' methodToken='0x600000e' ILOffset='272' />
  <Point module='PCMFrame.exe' classFull='ABB.PCM.Frame.PCMStartForm' methodName='a' methodSignature='Void a(System.String[])' methodToken='0x6000009' ILOffset='202' />
</ILExceptionData>
Такое сообщение выдаёт при запуске. Установка прошла без вопросов. Есть решение?
Re: Проблема с PCM600!
Попробовать запустить от имени администратора, т.е. правой клавишей на ярлыке программы, далее Запуск от имени администратор\Run as administrator.
Не получилось. Результат тот же.
Поставил второй жесткий с XP и проблема решилась.
Спасибо. Тему можно закрыть.
