Тема: MicroSCADA SYS600 v9.1.5
В работе имеется MicroSCADA SYS600 pro v. 9.1.5 с терминалами 5-ой серии. В терминалах REF543 изменены проекты. Соответственно необходимо создать файлы APL library для работы с SYS600. Пользуясь методикой изложенной в документации к CAP 505 (Смотри Приложение 1) создать работающий APL library файл не получается, создаются пустые файлы размером 4 Кбайта. Помогите, пожалуйста, разобраться в ситуации.
Приложение 1.
Uploaded application configurations in REF 54x, REM 54x, REC 52x and RET
54x object types
The REF 54x, REM 54x, REC 52x and RET 54x object types provide an alternative
of using an application configuration, which you can upload from the relay terminal.
Upon completion of the upload, you save the uploaded configuration into the object
type’s user application library. These application configurations are stored without
revision information and are available through the Apl library list, shown in
Fig. 3.9.2.1.-1. The use of uploaded application configurations is outlined below:
1. Insert the device object to the project.
2. Configure the object as explained above, assigning an empty application
configuration. Eventually you will replace it with the uploaded configuration.
Apply the configuration normally and then return to the Project Structure
Navigator.
3. Reopen the General Object Attributes dialog selecting the Communication page
to provide communication settings for the object. Select the communication
protocol and configure the communication settings. Connect the communication
cable, if it has not been done yet.
4. Open the object type’s configuration dialog. Click Apl Utils. and you enter the
dialog for maintaining the user application library.
5. By clicking Receive, the upload starts bringing up a progress indicator dialog.
Upon completion of the upload, you provide the name for the uploaded
configuration. This name will appear in the Apl library list.
6. Close the user application library management dialog by clicking Close. Now,
to assign the newly uploaded application configuration, check the Select New
check box and select the configuration from the Apl library list.
7. Close the object type’s configuration dialog by clicking OK. You are prompted
to confirm the replacement of the application configuration. Click Yes to
enforce the new configuration.
Re: MicroSCADA SYS600 v9.1.5
Коллега надо создать новые АR файлы в CAP505, потом их скопировать в MicroSCADA и там открыть.
Выбираете нужное реле, далее нажимаете язычок: Object Properties, затем нажимаете в окошке:
General Object Attributes язычок Attributes , открывается окошко: "название реле" - RE_54X Configuration в нём нажимаете на язычок Apl Utilis, открывается окошко: RE_54X- Configuration и в нём выполняете команду: Save Application to Apl Library--Save.
в открывшемся окошке записываете имя файла.
после того нажимаете на язычок Export Application from Apl Library-Export и в назначеной директории получаете файл с расширением AR.
Не корысти ради, в каком протоколе этих зверей подключаете?
Коллега, спасибо за ответ, но описанный алгоритм годится для случая, когда конфигурация программы поставляется АББ. В моём случае, программа неизвестна, поэтому необходимо выгрузить конфигурацию из терминала. Для этого выбираем нужное реле, далее нажимаете язычок: Object Properties, затем нажимаем в окошке: General Object Attributes язычок Attributes , открывается окошко: "название реле" - RE_54X Configuration в нём нажимаем на язычок Apl Utilis, открывается окошко: RE_54X- Configuration и в нём выполняем команду Receive Application from relay –Receive. Начинается выгрузка, при этом появляется окно с индикатором выполнения процесса. После завершения выгрузки задаём имя для выгруженной конфигурации. Это наименование появится в списке Apl library. После того нажимаете на язычок Export Application from Apl Library-Export в поле Apl library  выбираем конфигурацию из списка Apl library, назначаем директорию в Destination path, нажимаем кнопку Export и в назначенной директории получаем файл с расширением AR, но к сожалению размером 4 Кбайта (он пустой). Рабочий файл имеет размер от 40 до 120 Кбайт.
Убедительная просьба пояснить ситуацию и как получить рабочий файл.
Так то коллега совсем другая ситуация.
Весь вопрос а заложили туда те кто делал вам реле , то что называется RCT файл.
Без этого нечего нельзя выгрузить из реле.
Я пользовался другой методой кстати.
Заходите в Relay Download Tool
Нажимаете язычок Receive.
Ставите птичку на RCT project
Потом нажимаете на Receive.
создайте себе реле-демо с верным адресом.
Коллега, спасибо за ответ, но если проект скачан с терминала, зачем создавать реле-демо и как это реле-демо создаётся.
Мне всё-таки непонятно, методика изложенная в мануале ABB, указанная ранее в Приложении1, реально работает или нет.
Если скачен с реле, а если не скачен.
реле-демо, да просто потренироваться, в CAP505 создать новое реле и в него скачать.
по приложению 1, думаю ( да уверен ), что работает, просто никогда не было нужды использовать.
на самом деле проект вам обязан предоставить заказчик, у него должен быть диск back-up.
Хочу добавить свои пять копеек - не всегда RCT в реле это та конфигурация, с которой он работает, т.к. есть возможность заливать в реле отдельно скомпилированную конфигурацию и отдельно сам архив
100%, там для заливки язычки разные, но если кто так делает......ну в общем поняли коллеги.
а так всё, эра 54-й серии подходит к завершению ( к моему сожалению, за 14 лет я с ними сроднился :-) ). вот наверное в этом году последние проекты с ними и то продолжение старых и с ними уходит мой любимый ЛОН....эх, извините за офф...
Ну все равно их еще продолжат производить
