Тема: Проблема с PCM600!
Добрый вечер всем! )))
There was an unexpected error in PCM600: PropertyTable does not exist: 0c75caa0-3f6b-4029-a74f-b04249ee1513, _PCMFrame_
OS Platform: Windows 7 Ultimate
OS Service Pack: Service Pack 1
OS Version: 6.1.7601.65536
Processor Count: 1
Product Name: PCM600_2
Product Version: 2.4.1
Product Status: PRODUCTION
Product Build Number: 93
Application Domain: PCMFrame.exe
Assembly Codebase: file:///C:/Program Files/ABB/PCM600_2/bin/PCMFrame.exe
Assembly Full Name: PCMFrame, Version=2.4.93.0, Culture=neutral, PublicKeyToken=null
Assembly Version: 2.4.93.0
Assembly Build Date: 30.01.2012 10:29:32
Language Package: ABB PCM600 ru-RU Add-On
ConnPack Name: ABB Generic IEC61850 IED Connectivity Package
ConnPack Version: 2.4.3
ConnPack Status:
Build Number:
Path: C:\Program Files\ABB\Connectivity Packages\Generic IEC61850 IED\2.4.3\
ConnPack Name: IED Connectivity Package RED615
ConnPack Version: 4.0
ConnPack Status: PRODUCTION
Build Number: 50
Path: C:\Program Files\ABB\Connectivity Packages\RED615\4.0\
ConnPack Name: IED Connectivity Package REF615
ConnPack Version: 4.0.1
Build Number: 2
Path: C:\Program Files\ABB\Connectivity Packages\REF615\4.0.1\
Exception Source: ABB.PCM.ProjectDataServer
Exception Type: ABB.PCM.Data.Exceptions.PropertyTableNotFoundException
Exception Message: PropertyTable does not exist: 0c75caa0-3f6b-4029-a74f-b04249ee1513, _PCMFrame_
Exception Target Site: GetPropertyTable
---- Stack Trace ----
ABB.PCM.Data.DataStructureObject.GetPropertyTable(tableName As String)
PCMFrame.exe: NativeOffset 01060, ILOffset 0532
PCMFrame.exe: NativeOffset 01411, ILOffset 0679
ABB.PCM.Data.DataStructureObject.GetPropertyValue(propertySpecName As String, tableName As String)
PCMFrame.exe: NativeOffset 00282, ILOffset 0163
ABB.PCM.Data.SystemDataServer.GetRoot(toolName As String)
PCMFrame.exe: NativeOffset 00379, ILOffset 0174
ABB.PCM.Navigator.frmLogin..ctor(kernelObj As IPCMKernel)
PCMFrame.exe: NativeOffset 00358, ILOffset 0121
ABB.PCM.Frame.Starter.h()
PCMFrame.exe: NativeOffset 00086, ILOffset 0026
ABB.PCM.Frame.Starter..ctor(debugModeEnabled As Boolean)
PCMFrame.exe: NativeOffset 00608, ILOffset 0272
ABB.PCM.Frame.PCMStartForm.a(A_0 As String[])
PCMFrame.exe: NativeOffset 00368, ILOffset 0202
---- End of Stack Trace ----
<ILExceptionData>
<Point module='ABB.PCM.ProjectDataServer.dll' classFull='ABB.PCM.Data.DataStructureObject' methodName='GetPropertyTable' methodSignature='ABB.PCM.Data.PropertyTable GetPropertyTable(System.String)' methodToken='0x60001d2' ILOffset='532' />
<Point module='ABB.PCM.ProjectDataServer.dll' classFull='ABB.PCM.Data.DataStructureObject' methodName='GetPropertyTable' methodSignature='ABB.PCM.Data.PropertyTable GetPropertyTable(System.String)' methodToken='0x60001d2' ILOffset='679' />
<Point module='ABB.PCM.ProjectDataServer.dll' classFull='ABB.PCM.Data.DataStructureObject' methodName='GetPropertyValue' methodSignature='System.Object GetPropertyValue(System.String, System.String)' methodToken='0x60001dd' ILOffset='163' />
<Point module='PCMKernel.dll' classFull='ABB.PCM.Data.SystemDataServer' methodName='GetRoot' methodSignature='ABB.PCM.Data.IDataStructureObject GetRoot(System.String)' methodToken='0x60001e4' ILOffset='174' />
<Point module='PCMLogin.dll' classFull='ABB.PCM.Navigator.frmLogin' methodName='.ctor' methodSignature='Void .ctor(ABB.PCM.PCMInterfaces.IPCMKernel)' methodToken='0x6000006' ILOffset='121' />
<Point module='PCMFrame.exe' classFull='ABB.PCM.Frame.PCMStartForm+Starter' methodName='h' methodSignature='Boolean h()' methodToken='0x6000010' ILOffset='26' />
<Point module='PCMFrame.exe' classFull='ABB.PCM.Frame.PCMStartForm+Starter' methodName='.ctor' methodSignature='Void .ctor(Boolean)' methodToken='0x600000e' ILOffset='272' />
<Point module='PCMFrame.exe' classFull='ABB.PCM.Frame.PCMStartForm' methodName='a' methodSignature='Void a(System.String[])' methodToken='0x6000009' ILOffset='202' />
</ILExceptionData>
Такое сообщение выдаёт при запуске. Установка прошла без вопросов. Есть решение?
