Тема: RTU650 c тремя CMR
ваяю конфигу. вроде все по феншую, при компилировании не ругается, но, будучт залитой в устройство - не стартует. логи такие.
2018-09-12, 16:48:56.094 (ST TIV) CMU 0 [rack address 0, slot 2]: Starting up ...
2018-09-12, 16:48:56.094 (ST TIV) CMU 0 [rack address 0, slot 2]: Wrong rack or slot address.
2018-09-12, 16:48:56.358 (ST TIV) User Account Management on CMU 0 [rack address 0, slot 2] starting up ...
2018-09-12, 16:48:56.445 (ST TIV) User Account Management on CMU 0 [rack address 0, slot 2] running ...
2018-09-12, 16:48:57.094 (ST TIV) CMU 0 [rack address 0, slot 4]: Starting up ...
2018-09-12, 16:48:57.094 (ST TIV) CMU 0 [rack address 0, slot 4]: Wrong rack or slot address.
2018-09-12, 16:48:57.094 (ST TIV) CMU 0 [rack address 0, slot 6]: Starting up ...
2018-09-12, 16:48:57.094 (ST TIV) CMU 0 [rack address 0, slot 6]: Wrong rack or slot address.
2018-09-12, 16:48:56.762 (ST TIV) XRP Server on CMU 0 [rack address 0, slot 2] starting up ...
2018-09-12, 16:48:56.762 (ST TIV) XRP Server on CMU 0 [rack address 0, slot 2] running ...
2018-09-12, 16:48:57.358 (ST TIV) User Account Management on CMU 0 [rack address 0, slot 4] starting up ...
2018-09-12, 16:48:57.357 (ST TIV) User Account Management on CMU 0 [rack address 0, slot 6] starting up ...
2018-09-12, 16:48:57.446 (ST TIV) User Account Management on CMU 0 [rack address 0, slot 4] running ...
2018-09-12, 16:48:57.444 (ST TIV) User Account Management on CMU 0 [rack address 0, slot 6] running ...
2018-09-12, 16:48:57.758 (ST TIV) XRP Server on CMU 0 [rack address 0, slot 4] starting up ...
2018-09-12, 16:48:57.759 (ST TIV) XRP Server on CMU 0 [rack address 0, slot 4] running ...
2018-09-12, 16:48:57.755 (ST TIV) XRP Server on CMU 0 [rack address 0, slot 6] starting up ...
2018-09-12, 16:48:57.756 (ST TIV) XRP Server on CMU 0 [rack address 0, slot 6] running ...
2018-09-12, 16:49:01.550 (ST TIV) CMU 0 [rack address 0, slot 2]: Startup stopped.
2018-09-12, 16:49:02.100 (ST TIV) CMU 0 [rack address 0, slot 6]: Startup stopped.
2018-09-12, 16:49:02.149 (ST TIV) CMU 0 [rack address 0, slot 4]: Startup stopped.
но. если оставить только три CMR, то работает. я так понимаю, что весь затык происходит после добавления слота входов и шины SPB I/O BUS. что я делаю не так?
пару скринов когда работает и не работает, причем после добавления слота входов, компилятор настоятельно требует добавить SPB I/O BUS
релиз ртутил 12
Добавлено: 2018-09-14 11:43:56
джемпер на корзине. S1. номер RUCK. надо поставить первый номер. странно всё это.... но видать так должно быть, работаем дальше, спасибо!
сори ежели побеспокоил, реально три дня потратил.
Добавлено: 2018-09-14 13:46:44
еще странно, что будучи физически назначенной с номером 1 корзина в логах идет под номером ноль
http://rzia.ru/uploads/14211/thumbnail/qYEdTr3jaiDu7ZX2CzLb.png
