Тема: Моделирование трансформатора в MatLab
Всем добрый день! Стоит цель смоделировать модель сети. Имеются 2 автотрансформатора, с заданием параметров которых и возникли трудности.
1) Что подразумевается под током ХХ нулевой последовательности? (Zero-sequence no-load excitation current with Delta windings opened
The no-load excitation current in percent of the nominal current when zero-sequence nominal voltage is applied at any three-phase winding terminals (ABC, abc2, or abc3) connected in Yg or Yn.
Note: If your transformer contains delta-connected windings (D1 or D11), the zero-sequence current flowing into the Yg or Yn winding connected to the zero-sequence voltage source does not represent the net excitation current because zero-sequence currents are also flowing in the delta winding. Therefore, you must specify the no-load zero-sequence circulation current obtained with the delta windings open.
If you want to measure this excitation current, you must temporarily change the delta windings connections from D1 or D11 to Y, Yg, or Yn, and connect the excited winding in Yg or Yn to provide a return path for the source zero-sequence currents.) и как его задать?
2) Аналогичный вопрос про потери ХХ нулевой последовательности.
Картинку с окном задания параметров прилагаю.
